Hm, good point; the only way I can think of right now is to run the RT render server manually with the -numThreads command line option. But we should do this internally…
It is, under Settings > advanced > max render threads, but it is designed to affect the production renderer. Maybe if we make it to also affect the render server for RT. I’ll put a note in our system on this.
Yeah, Yolov. We were referring to the Max render threads for RT CPU as that feature for production renderer is already available.
To me, it makes more sense to have Max render threads UI exposed separately in the IPR tab so I don’t have to switch back to the Settings tab for that. Typically, I would reserve more threads for RT CPU as I will be tweaking stuff in UI frequently. And for production rendering, I would go full on with threads. As far as I know, IPR and production rendering can be set of different CPU thread number in both PRMan and Arnold…
