Is it possible to render curves with vray, similar to how one can do this in renderman?
thx!
Just add extra v-ray attributes to shape node of the curve
you can also select a group of curves and add vray renderable curve node to control them all at once.
Can you be more specific as to how to do this please?
in maya if you go to create menu, under vray, select create vray renderable curve >> apply single control node for the selection. You have to have your curves selected first. It will create the control node for that selection. Those nodes are basically mutual/exclusive sets, so you can add/subtract curves from it as you please.
I checked in both the current version (Maya 2013, vray 2.3) and in the latest stable version and I do not see that option in the vray create menu. What version are you using?
Also when I apply the vrayHairMtl3 to the curve I get a fatal error:
// Error: Exception [module=1] : Rendering region (0,0)-(64,64) //
// Error: There was a fatal error rendering the scene. //
and it fails to render, crashing Maya on some machines
Is this a known bug? The vrayMtl seems to work fineā¦
