rendering ocean, Fog issue
Im trying to have more sense of depth but as soon i move the fog depth there is no fading at all
Hello @philippe_grasset ,
You need to increase the Depth further if you want to make the Ocean water more transparent.
Here is how it looks like in my example scene with Depth set to 30 cm on the left and 300 cm on the right:
Let me know if this works for you.
Kind regards,
Iva
Hi this worked, i have another issue though , i think is because of the seabed, which is a simple surface, the problem is that on horizont view it renders the edge as a black line, how to avoid it?
Hi @philippe_grasset ,
I am glad it helped.
Are you using Environment Fog? It creates such an edge when the Distance and Height values are very high.
Kind regards,
Iva
I found out is the glossines
