I downloaded a piece of furniture from google’s 3d warehouse, and I imported the sketchup file into rhino.
However, when I try to render my sketchup model in rhino using v-ray, the model doesn’t render.
It is invisible in my v-ray rendering.
Why is this? How can I fix this problem?
sometimes sketchup materials don’t render properly in vray for rhino - the meshes look one-sided or inside out. try assigning a new material to the geometry. make sure you explode blocks first.
1.) Explode & Ungroup the object.
2.) Select the object.
3.) Properties > Material > Assign material by “Layer”
4.) Assign your own material to the layer which has this object.
“Most of the time when this happens, it is due to a corrupted materials. Go to Global Switches and enable the “override materials”, if you are able to see the render, then it is a material issue, if you still getting an invisible render, then could be geometry.”
