Request 4_Exclude invisivel light on volume material
hello,
Sometimes i have extra light invisivel, and when use volume material this lights are contribut on volumetric.
its possible on the future desable invisibel lights on volumetric? like a caustics, disable obejct than can contribut caustics.
thanks, good work
If you are using a global volume material, then there is probably no way to do it, but if you are using a box object for the volume material, you can exclude that box object from the Corona Light’s influence.
If you are looking for something else, please let us know, and it would be best if you share some screenshots or simple scenes as an explanation.
thank you very much.
You’re welcome!
