I wish a reset option, and if posible a save and load settings.
reset curve color correction
If you right-click in the curves window, you will get a menu, which has “load” and “save” options. Will take a note about the reset too.
Thanks Vlado, other useful thing could be having a cross in the corner of the color correction window, to close it. Because if you close the frame buffer window, its imposible to close it.
It’s already done; also the color correction window now closes automatically if you close the main VFB window.
OK, Thanks !
so if one correct the curves
is it just for viewing purposes
or does it apply when saving the image
does it save the image as in corrected state
It saves with the corrected color state
