I may be searching with the wrong terms but I can’t find this sissue in the forum. When I render and then turn on “color curve correction” my image saves correctly with the correction. When I render multiple frames for an animation it does not apply the color curve correction to the saved frames. Is there something else I need to check or turn on somewhere? Thanks.
How do you save the images? Through the Common tab of the Render Setup dialog, or through the “Split channels” option of the V-Ray VFB?
All this time I’ve been doing this and never realized that was in there. Guess I need to study up a bit more. Thanks Vlado!
