(Resovled) Batch rendering multiple camera
Is there any way to batch render multiple camera? I can’t find any info in the help.
make muliple rops with different camera or use takes
Hey @creac ,
as Ronald has stated in the post above mine, at the moment the simplest way to do this would be to use multiple Renderer ROPs.
Hope that helps!
Hi, how do you setup multiple rops with different cameras for batch rendering? I have got an error message…
imho the IPR node is kinda irrelevant - you can shift click on the IPR shelf button to choose which vray rop to get rendered.
@glacierise noted, but then I can’t batch render - I have to choose between cam1 or cam2. Is that correct?
Hey @creac ,
You shouldn’t be piping the Renderer ROPs into the IPR ROP but a Merge ROP instead. That should do it :slight_smile:
The purpose of the IPR ROP is internal - it has to be present for the IPR to work but as @glacierise mentioned - you can switch which camera is used in the VFB itself.
Best regards!
@Gosho.Genchev awesome! Thx
