Just rolled out 4.12 to office and noticed that the Revit 2022 is gone. I’m assuming there was a version cutoff for 2022. Can you let me know which build was the last version for 2022? Thanks.
Hey,
Starting with Enscape 4.9, we no longer support installation for Revit 2022. The last version that fully supported it was 4.5.
As announced with the 4.4 release, we will remove support for older host versions about three months after adding a new one. This policy came into effect in 4.9 — three months after we added support for Revit 2026. Doing this helps us maintain a more streamlined development process, improve stability, and focus on the most current Revit versions.
We understand that many firms run multiple Revit versions across different projects, and that upgrading isn’t always simple or immediate. You may continue using an older version of Enscape if you need compatibility with Revit 2022, but please note that we cannot guarantee support for issues that arise with versions outside our current system requirements. You can download an older version of Enscape here.
Please let me know if you need anything else!
Thank you
