Supported Versions of Revit
I’m starting to test out the latest version of Enscape 4.18.1. Before I get too deep into it, can you please confirm which versions of Revit are compatible? I couldn’t find this documentation in the Release Notes.
Specifically I need to know if Revit 2023 is not compatible with Enscape 4.18.1 and more importantly where the cutoff is. To phrase the question another way, what is the newest version of Enscape that will work in Revit 2023?
Hello @andy_brack! Enscape 4.18 added support for Revit 2027 and since we are supporting the latest 4 Revit versions, that would make Revit 2023 out of support for 4.18.
So the newest Enscape version that works with Revit 2023 is 4.17.
Okay. So that’s what I thought would be the answer. The weird thing though is that I tested it directly and I can still run Enscape 4.18.0 within Revit 2023. Can you check on your end?
It can still work but we won’t guarantee that it will perfectly.
