anyone else getting this message pop up non stop?
just installed latest enscape version.
Hi @JDH_2
Can you please send us your log files via the Enscape Feedback Button and we can look into this.
Thank you in advance!
thanks. done :thumbup:
I’m facing the exact same issue here. When using certain tools (most of the time when editing any Revit object) this message constantly pops up.
This occurs whatever enscape is running or not.
I’ll send a feedback too.
Yeah sometimes it just continuously pops up non stop. X/
loving the new content though
:revit:
Thank you - the feedback report will be rather helpful!
no worries at all.
I am also on the latest preview version of enscape.
same problem here as well…looking forward to a solution!
any solution on this yet? We are finding we have to disable enscape or revit 2022 performance is awful.
Same here. Any update?
Enscape is still causing revit to disappear if in the material editor after seeing that pop out. I don’t know how to send feedback after revit just disappears.
Likely Enscape conflicting with another Revit plugin. Can you temporarily disable or remove the other plug-in and try again?
Una vez que quiero abrir enscape para abrir cualquier archivo sea este o los modelos establecidos en Revit siempre arroja un diálogo muy molesto que dice " Enscape esta esperando la respeusta de la API de Revit. esto podría estar bloqueando el progreso". AYUDAAA
I’m hearing one of our employees is having this issue frequently, using Enscape 3.4, Revit 2019.2.6.
Any resolution or insights?
As Phil mentioned, does temporarily disabling or remove any other plug-ins resolve this for you?
If so, please let us know and send us a feedback report including the log files as seen here.
Please also add a link to this thread in the description for context.
Hi, having same issue with API while using enscape. Is there any solution to this?
Noticed it started happening after upgrading to new enscape version.
Is it recommended to downgrade enscape version?
Thanks in advance.
I have experienced it as well, often when I’m working with larger and more complex custom assets.
As detailed by my colleague above, please try to also disable/enable other plugins alongside Enscape to see if that helps. If not at all, then kindly also provide us with a dedicated feedback report which you can submit as we detail here.
Same issue here, wonder if anyone knows what the issue is. Restarting Revit session seemed to fix the problem… until it happened again
I’ve not gotten this resolved unfortunately.
I have realized that this is only happening when I have Enscape open and I’m trying to import a family to the open project.
