Revit grass not working
hi, i am trying to figure out how to run grass in revit 2019. i have material named Grass and grass option checked under advanced panel but it still doesnt work. same issue with water material.
any idea? i have no issue in sketchup, the grass and water works just fine, in revit it doesnt so it is weird.
version 2.3.3.0
thanks
Hey @cavo , I’m sorry to hear about that. Could you briefly update your Enscape to version 2.4.1 (which is our latest release), let me know in case this issue still persists and if so, could you please send me a screenshot of the material right next to the open Enscape window in which we can see the Grass not rendering?
Also, regarding the water material, instead of using a keyword (like you do in SketchUp), please set the material class to Water, and Enscape will render the material as animated water with refraction and caustics. Enscape will take the settings set in the water material into account and display them accordingly. :slight_smile:
