Revit Material
Do I have to set-up Vray materials again if I’m gonna open it to another computer?
So, I have 2 computers connected to the server and 1 Vray license. I applied Vray materials using my computer, then decided to render it on another computer. But when I opened the file to the other computer, all the Vray materials went unmapped. Is this normal? Do I have to re-mapped the Vray materials to the other computer?
Hi Andrew,
1. You need to export the settings (Settings->Sharing->Export Settings)
2. When you open the project on the other machine, you need to load the settings
3. Finally you need to set the paths to the materials under Material paths in the Settings dialog.
That’s it.
