Revit View VS Enscape view
How to make Revit view tally exactly with Enscape view setting? I hope it tallies exactly when it comes to the following considerations:
  • Window view size
  • view setting
  • sun setting
  • Field of View
  • Two-point perspective / or non-point perspective
Chose the Revit view, adjust the aspect ratio of your window and set the field of view. Then it shouls match 100%.
The sun position is automatically transferred from Revit to Enscape.
Do not use Two Point here. Two Point is a distortion of the image to force vertical lines being vertical in the image. It might be useful for certain rendering perspectives but in general it should not be used.
There’s no way to handle a 2 point view out of Revit? This would be great along with the ability to save the view in Enscape.
