RGB tint cannot be rendered in vraydome map
If the map card slot in the vraydome light contains RGB tint Then it will not be rendered
This material node should be supported
Figure w001:
Color correction - RGB tint - vraybitmap (not rendered)
Figure w002:
Color correction - vraybitmap (everything is normal)
There should be a warning that it isn’t supported. It’s written in the docs as well. Here’s a workaround (screencap) - manipulate the VRayColor nodes to get the tint. Although, I think it would be simpler in PS.
I thought this was a bug that could be fixed. Sorry.
Your solution may be one of the alternatives, but it’s still too complicated. RGB tint will be simpler
RGB tint is used to remove a certain color from HDR instead of adding a certain color. It can always achieve the desired effect quickly. If it is not particularly difficult, I hope it can be supported
Vantage could not achieve this before. Later, they completed this function. Maybe vraygpu can also support it
Because I switched back from vantage to render some scenes, I found that RGB tint was not supported.
Just so you know, I’ve logged an improvement request (internal bug-tracker id: VGPU-5912) for RGB Tint’s support on GPU.
Thanks for your help
