Probably this is the bill to pay after using nightlies builds, but I can’t open Rhino files with vray scene I set up on september 2012
Every try I give ends up with crash
Last time I used another pc with rhino without vray and it opens the damaged files without problems..
Never had that problem.but may be you could try to
open Rhino desactivate vray render,close rhino
open the file,it should open,save,close rhino
open rhino reactivate vray,and open the new saved file
Renee
I just updated to 1.5_22805 !!! problem is gone!8)
Renee, I tried before what you recommend - does not help. But after erasing the dome and infinity plane (from rhino where vray is not installed) and save as another file later I was able to re-open it!
thanks anyway!
