HI all,
So I’m in RHINO 6 with the latest enscape version. I normally set my cameras using the named views window and display the safe frames on my viewport. Also the resolution and quality of the viewport is set in rhino options under render (see image bellow).
For a reason that I ignore the batch render in Enscape does not render to the image as per Rhino’s aspect ration. If I render the view manually it matches the Rhino aspect ration perfectly. Enscape capture settings have the same image size as my viewport (see bellow)
Anyone with this kind of issues. Should I set the images using Enscape instead of Rhino’s cameras?
Thank you in advance
