when I import Rhino 7 file into Revit and open Enscape, some materials don’t show
both sides, one side been transparent. They look ok in Revit 2019. Any suggestion?
Attached Enscape and Revit images…
@jlopes , welcome to our Forum! ![]()
It looks like during the import process only one side gets the material applied - does it help if you simply apply the correct materials on the other side as well in Revit? Otherwise, it would be great to receive the project too (via a DM) so we can have a look at it.
Hi Demian,
this is the Rhino file. When I insert it into Revit as CAD Import,
I can’t change the material and only use Overrrite Graphics in View to change its color, but it doesn’t affect Enscape appearance.
However, I can change material in Rhino and export into Revit again, but the transparent side continues in Enscape and some panels disappear.
Please let me know if you need the Revit file, but I’m testing it with an empty file using Rhino 7 and Revit R2019.
Thanks in advance.
cats eye panel.zip (4.6 MB)
Hi Demian,
I’m still struggling to get this issue fixed.
Could you check it for me?
Thanks a bunch…
