Rhino Sun + Dome light intensity issue
After updateing to v. 5.1 (or 5.2) I have an issues with default Rhino Document Sun inside Domelight.
I used to render with lightmix and then lower the sun intensity in case of need. But with new versions, by lowering the intenstiy I have an artifacts.
The solution so far is to disable rhino sun and create a new vray sun - it works just as before.
Hey @pavol_pastork ,
Is it possible to forward us the 3dm file so we can have a look? You can send it via our contact form, just make sure to mention this thread in the subject. Much appreciated!
Hey @nikoleta.garkova
I send it as you mention. Thank you
