Hi all ![]()
Yesterday i played around with some Megascans assets and other models I had lying around
The result was this nature scene. Hope you like it.
WUNDERBAR !!! <3 ( & another one for my personal Enscape Hall of Fame!)
please please add a screenshot of your model
(the mood is almost a little bit like these romantic landscape paintings from the 18th century)
… my (completely irrelevant!) advice: leave it as it is - it is already perfect
Thanks for sharing this
not far from where I grew up, this castle ruin, of which there are so many in my area, was frequently visited for a sunday afternoon walk - somewhere in the middle of the forest - a paradise for children and somehow just like you hit it above ![]()
That looks like an amazingly cool place! i would have loved to play there as a kid
And you are right, its a lot like the one I imagined ![]()
Very cool! Btw, are you using transmutr to bring the megascans assets into Sketchup, or some other method?
Nice rendering , hope to see your RAW render image without Photoshop !!! :v
Thanks! Yep, I use Transmutr to bring them in
It is quite powerful and very fast! My prefered way is to export as enscape proxy with “simplified geometry” (it uses whatever simplification amount you’ve selected on the slider above… just go to 98% or something like that). that way it is still very easy to set up your scene with good referencemodels.
Thanks. The raw image is pretty similar to the final image. only colorgrading, a little fog and some contrast stuff has been done in photoshop
Here is the image straight from enscape:
I bow to your skill , Herbo !!!
Thank you very much! ![]()
Great work Herbo, love it!
Really does look quite a bit like the scene @EGIESTO shared.
Ohai @Herbo , can you tell me what settings you used for transmuting the grass from Megascans to transmutr to skp please, it drives me insane.
Here is what i get, on the left is the 3D asset as seen in Megascans Bridge and on the right is this completly useless 3D asset rendered in Enscape.
right now i’m in a summerhouse without access to a real pc and enscape, so i can’t verify this… but… i recall an issue with transmutr and enscape, where the UV mapping of textures are corrupted whenever a transmuted material is edited in enscapes material editor. to get around this, use the plugin called sketch-UV. with this, you can right click on a surface BEFORE editing the material, and click "save UV’s). then you can edit the material as you please, and when the UV then screws up, just right click the surface again and select load UV. this should fix it ![]()
Geez, i wouldn’t find out by myself. I’m gonna try it and get back to you
Thanks a bunch
AMAZING work.
I’ve had the same issue from transmuted models for the past 3 months but realized there is a very simple fix. Before you start adjusting materials, remember what the default scale measurement is in the material window for sketchup (for U.S. its usually 10"x10"). When you start adjusting normal maps or roughness, notices that number jump and the albedo gets screwed up. Go back to the scale measurement and return that number to its original and that should solve the UV mapped issue.
Let me know if that makes sense or works for you.
Can confirm this works - have had the same issue with Maxtree assets. This is actually an old problem I used to have with VRay proxies too.
Well, looks like i found the issue, both the UV stuff you were talking about and the “Explicit Texture Transformation” in the material editor of Enscape that doesn’t follow along.
Check it here ==> My favorite place on earth
Thanks muchly for leading me the way !
Just to make sure I’m understanding you correctly, when you try to adjust the corresponding “Explicit Texture Transformation” the material simply stays unaffected? Can you first off confirm, and also make sure then that you’re using our latest release? ![]()
