the green material is the grass material i downloaded from the materials. problem is the differenc ein color, even though same material selection. the darker one is incorrect and should look like the lighter one. i know the geometry is not perfectly flat on the darker greeen ones, but that shouldn’t affect it. please help, photoshop will take too long.
Re: same material, different color grass)??
Make sure that the normals of those surfaces are facing the right way. Chances are that the grass material has a displacement on it, which requires having the normals oriented correctly to look right
