Hi everyone, currently trying my first project using the VFB to do the final colour grade, and i’ve got an issue i cant seem to figure out, i might not be seeing the forest for the trees.
I’ve got 50-100 images to render in a large format, so the build in max buffer is off, resolution set in vray. There’s a few curves adjustments; some using a cryptomatte mask, and a sharpen. Is there a way to save out a final .png if i send them to render via backburner? Using save channels spits out all the cryptomatte files, and i get an rgb with appended file names from the sharpen, using save raw image wont work as it doesn’t support .pngs, and the default max save option doesnt work because the max frame buffer isnt used.
any help would be appreciated.
