Saving Render Preset Problem
when saving render presets, some V-Ray settings are not saved.
I’ve tried saving/loading settings (.rps file) on different hard disks, in CPU, in GPU, in Max 2024, in Max 2023…
I can’t save my rendering settings in their entirety.
Is this normal?​
Hi, thanks for posting. You have to select all categories
What is missing? Do you end up with the same settings not saving/loading or there is random element to it.
Please give us a bit more details.
All categories are selected except “common”.
I don’t select the “Common” category because I don’t want to modify the different output sizes of my different files.
An example of settings that don’t save:
-​ Fit resolution to VFB
- Noise Limit
- Light Cache Subdiv
- Auto RGB primaries for VRayBitmap texures
Hi, you are correct. All of the above mentioned settings do not save and don’t load with V-Ray GPU. I logged the issue under VGPU-6298 in our bug tracking system for developers review.
Hi Vladimir,
glad to hear that the problem was not mine.
My list is not exhaustive; I haven’t checked all the settings.
