Scale in orthographic render
Is this possible to make an orthographic render with enscape at a specific scale ?
For exemple, actually if I want an elevation with enscape by orthographic method, I can’t make directly it in enscape at 1:200.
Someone know how to make that ?
Ortho exports to “scale” : This thread was about the same pb but there is no evolution since 1 year. Maybe, this scaling subject evolved?
By extension, maybe annotativ family could be visible in enscape rendering… =O
PS : Sorry for my english, I’m french. :slight_smile:
Thanks.
There’s no scale in Enscape for images. Just resolution. Render larger than you need so that you can resize the image down in order to adjust the scale that you require.
I recommend including a square object around whatever you are rendering at a specific size. I have often in the past made this my paper size scaled by the size you need.
For letter size at 1:200 scale you would create a 200x8.5" x 200x11" size rectangle.
Thx for the tips.
:wink:
