scaling vray hair
because of maya we still export our hair in maya scale and in the lighting scene in houdini we scale it down a 100 times. The issue is that even if visually in the scene the hair lookds like they are the same size the width and the absolute distance on the hairsampler becomes 100 times smaller. With width we can scale it export a 100 times but not the hairsampler. Could we add a global control for this? bonus would be the hair shading in the viewport to be matching.
I hope the scene clarifys what i want to achieve.
https://drive.google.com/drive/folders/1AIhIKP48e2B\_v57a62wRSqmi5bOAy8T6?usp=sharing
Regards Alexis
but the results with absolute distance is different for the 2 objects that have exactly the same scale in the scene. so we cant make 1 shader for both of them.
This screenshot I’ve posted shows a single shader for both objects.
User float default value is set to 1.0.
Scaled object has that user property (primitive attribute will also work) value set to match scaling (0.01).
i get that, the problem is that some lookdevers likes to use the absolute distance. So people get confused when 2 objects that has the same size in the sxene has 2 totally different results(same with width). If its not possible i understand, just wanted to check if there is a way to control it so abosulte match in this case i sent you.
