hair width control with USD in Maya
Hi, I have a USD stage coming from Houdini into Maya. It has a geometry and a hair groom (basis curves)
I am able to use the point attrubutes/primvars in lookdev X to control material aspect of the hair like melanin or other mappable attributes.
What I can’t really seem to control is scaling the thickness of the hairs. I have exported a width attribute from Houdini and from the get-go this seems to be ignored in Maya,
meaning I get infinitesimally small width at rendertime. I can’t seem to attach any attributes from Vray in the Attribute Editor/Attributes.
I also tried to add a primitive to the USD stage that supposedly has control over given curves’ width or thickness, but this just adds that node to wherever you right clicked on the USD stage’s hierarchy.
This node in no way speaks to the groom curve’s node, if I parent it to the groom changing the thickness, I get no effect and going the other way, trying to parent the curves under the VrayGeomHair node is not possible.
Please if anyone has a solution or advise in any way, that would be very helpful, thanks!
Can you post the scene or a repro of the USD file.
@hsz I actually managed to fix the problem with getting the initial width out of Houdini to correctly reproduce in Maya at rendertime. Turns out I needed to scale up the widths x100, same as I would do for geometry. I also specified what to do with Nurbs curves (convert to basis curves), kind authoring (last option) and path attributes (path, name) and it worked with the proper width. I still don’t know how I would further control the width in Maya once imported. This would be in line with look development. I can’t seem to upload USD files here on the forum for some reason so can’t really share anything for troubleshooting. Thanks
You do it through BF USD. Easiest way and Vray supports it.
That’s great. Thanks, I’ll give that a go!
