Scatter Collections
I was testing the new option to scatter collections, and there’s something odd:
If I add single objects everything works as expected. If I add a collection the position of the objects is some transferred into the scattered instances. If the objects of the collection are positioned close to the plane - in this example - they are scattered around the plane, not on the plane.
I guess that’s not the way it should work?
Screenshots attached.
This is expected(at from what we implemented) and is how Blender’s legacy instancing of collections works I think. I guess you want to add the full collection as separate object without their transformation? I did initially add an option for that but ended up removing it, but it can maybe be re-added.
Thanks for the fast response. If it is expected behavior, everythings fine. I just expected the Chaos Scatter to clean the transforms in the background. That’s how other plugins like Openscatter e.g. handle it - I guess at least, because there the position of the objects does not influence the scattered instances. A button would be handy, but since I know I don’t got anything wrong initially while setting up I can deal with that.
