Scatter doesn't respect bercon noise
Hello. I just found out that scatter doesnโ€™t respect berconnoise in animation when using world or object space.
Are you aware of this?
Only World Space coords donโ€™t work on my end (check the attached scene).
sample_berconscatter.7z (13.6 KB)
Tried it in 3ds Max - all modes work there; the World coords yield a jittery scatter, which I reckon is expected, due to sample differences in the reevaluated world space tex on every frame.
Otherwise, whatโ€™s your goal with using obj/world space? Or youโ€™re just reporting it.
Your sample scene does not work. Trying animating your cam and render a sequence.
My goal this that I can use world and object spaces for scattering, and that it works with animation. Yes, uv space is a workaround but the default setting for bercon object space at least, would be nice to have working.
๐™ทฬถ๐š–ฬถ,ฬถ ฬถ๐šขฬถ๐š˜ฬถ๐šžฬถ ฬถ๐šŠฬถ๐š›ฬถ๐šŽฬถ ฬถ๐š›ฬถ๐š’ฬถ๐šฬถ๐š‘ฬถ๐šฬถ ฬถ-ฬถ ฬถ๐šŠฬถ๐š—ฬถ๐š’ฬถ๐š–ฬถ๐šŠฬถ๐šฬถ๐š’ฬถ๐š—ฬถ๐šฬถ ฬถ๐šฬถ๐š‘ฬถ๐šŽฬถ ฬถ๐šŒฬถ๐šŠฬถ๐š–ฬถ๐šŽฬถ๐š›ฬถ๐šŠฬถ ฬถ๐šฬถ๐š’ฬถ๐šฬถ ฬถ๐š›ฬถ๐šŽฬถ๐š™ฬถ๐š•ฬถ๐š’ฬถ๐šŒฬถ๐šŠฬถ๐šฬถ๐šŽฬถ ฬถ๐šขฬถ๐š˜ฬถ๐šžฬถ๐š›ฬถ ฬถ๐š‹ฬถ๐šŽฬถ๐š‘ฬถ๐šŠฬถ๐šŸฬถ๐š’ฬถ๐š˜ฬถ๐šžฬถ๐š›ฬถ.ฬถ ฬถ๐™ธฬถโ€™ฬถ๐š•ฬถ๐š•ฬถ ฬถ๐š•ฬถ๐š˜ฬถ๐šฬถ ฬถ๐šฬถ๐š‘ฬถ๐šŽฬถ ฬถ๐š’ฬถ๐šœฬถ๐šœฬถ๐šžฬถ๐šŽฬถ ฬถ๐šฬถ๐š˜ฬถ๐š›ฬถ ฬถ๐š’ฬถ๐š—ฬถ๐šŸฬถ๐šŽฬถ๐šœฬถ๐šฬถ๐š’ฬถ๐šฬถ๐šŠฬถ๐šฬถ๐š’ฬถ๐š˜ฬถ๐š—ฬถ.ฬถ
EDIT: Actually, it seems to work for IPR only (didnโ€™t test prod on my scene), and Iโ€™ve found that we already have this issue logged (VMAYA-12435). Will bump its priority.
Thank you. Iโ€™m happy that you could replicate the behavior. I think itโ€™s rather important to get fixed.
