Hi. This has been a huge pain in the rear for me for a long time. Quite often when I use IPR and change stuff in my scene, move things around etc, scattered Forest Pack objects start losing their materials and become black or white. This happens on all PCs here. I once reported this to Itoo and they said that it’s an issue with V-Ray and they can’t fix it on their side. This heavily slows down lookdev since I constantly have to stop and start IPR. Is there anything that can be done about this?
this doesn’t seem reproducible in a newly created scene on my end. Could you send a scene sample where this can be observed to philip.shounev@chaos.com so we can locate the culprit ?
Hi ![]()
Did u find a solution for this?
Cheers ![]()
It tends to happen when you change items in the geometry list of the forest pack object. FP creates a multimaterial encompassing the materials from the items it contains, so presumably when the geometry list changes and IPR refreshes, this multimaterial is not updated and then incorrectly assigns materials to the items it is scattering.
You guys can use IPR with ForestPack objects on??? :shock:
By changing items in the geometry list do you mean adding / deleting entries from the list or some other changes? I still cannot reproduce that so it would be really helpful if you could provide additional details or a scene sample to philip.shounev@chaos.com.
Yes, adding and removing items (with their own materials) while IPR is running. I don’t have time right at the moment to supply a scene but for me this has been a feature/issue for many years. \
This could also be a different issue from OPs!
Here it seems to happen when FP object use edge mode. As the issue is sometimes here and somestimes not, i also cannot supply a scene to reproduce…
Ok perhaps this is a different issue to mine then.
