scattered objects exceed borders
why are the scattered objects exceeding the borders of the area given ? I need to keep them inside. Thank you
corona 1.3 & max 2014
That is because instances are scattered by their pivot points, not by bounding boxes. You can counteract this by making distribution area little bit smaller, either with density mask or with geometry itself.
thank you
