I went through the ship ocean tutorial and it says to change the scale to meters. If I were to make a calm ocean using the preset would I also need to ensure I’m in meters as well?
Hey,
The way that you display your units doesn’t matter as long as your simulator size is in the correct scale. You should be totally fine to use centimeters.
Yes my ship is correct in scale so that is good to know that I can use cm.
