Screen freezes when I press "RENDER" button (3DS MAX)
Hello everyone,
I’ve just got a new job and I’ve installed 3DS MAX 2018 (trial) and Corona 1.6 (trial), but I have a problem.
As soon as I begin rendering the screen freezes, I cannot do anything.
If the scene is EMPTY, no light nothing, it would render for about 700 passes (1-2 mins) and if I open another software it freezes. The CPU is being used by 80+% during empty rendering. And if I try to render with anything in the scene then it freezes a second after I press the “RENDER” button. I can see the silhouette of the object, but then it freezes. It seems like it doesn’t have enough strength, but it’s impossible coz its a 4.4Ghz CPU!!!
Please help
!(http://[img]
Sys[/img]tem:
CPU: AMD FX™-9370 ()4.4 Ghz 8Cores)
GPU: Zotac GTX980ti
RAM: 16GB
OS: Win 7 64 bit.
(this is also submitted in a form of support ticket, we just need a little bit more info, and will provide solution asap)
Corona 1.6 Latest.
Solved over the support portal. The culprit was some kind of hardware malfunction, probably due to overclocking.
