Hi guy
I want a backplate in RTX mode, but it is not working. Is this mapping type supported on GPU rendering?
It is working fine if I use CPU
The latest version of V-Ray 6.10.01
Hi, javierrentas
This is a known issue that has already been logged in our bug-tracking system. We’ll let you know when there is an update on the development.
As a workaround, set the Environment Background multiplier to 1 and use the V-Ray Color Correction texture to increase the intensity of the HDRI. Please, let me know if this works for your project.
Kind regards,
Natali Velcheva
Hi, javierrentas
I would like to notify you that the described issue is fixed in the 6.10.02 build.
Thank you again for reporting it!
Kind regards,
Natali Velcheva
Thank you!
