I have a small, enclosed bathroom scene, where I’ve applied shiny metal materials to the plumbing finishes (faucets, shower head, etc.). However, as you can see in the attached image, they appear quite dull:
I’ve tried various different metal materials, but they all seem to give a similar, dull effect. I think I have plenty of light in the scene?
Anyone have tips on how to improve the shininess and give these metal objects more pop?
Does creating additional lights that only affect these metal objects make sense?
Is your ref.gloss turned up toward 1. That should make them look more chrome/shiny versus brushed. The tub faucet in particular, looks to have an overly low gloss. Use black diffuse too
Since its the siger ball, I guess it is the complex fernel osl. If this is an original siger shader, the metal material is most likely pretty accurate. I think its probably the scene.
Show us your camera settings.
the reflections in your render look clamped do you have by chance subpixel mapping on?
In any case vray’s frenel function works just fine if you use it correctly. Usually metal is less diffuse and more reflective. If your other objects in scene look fine and metal does not, I don’t think its the camera. Try stay as physically accurate as possible to real world and you won’t have to fake your way around it.
ditch the VMPP and make your own, much nicer and easier
you could try a basic blend material with a slightly glossy base layer to help make them shinier
i think alot of people are now using vmpp shaders alot and alot of the time they dont seem to work well without tweaking and i think its a result of overthinking the shaders much like what Grant does sometimes in his tutorials, its really complex for no reason, dont mean to make anyone mad but its easier to make your own shaders, i agree with the advice below with the link to VISCORBEL, some of the best tutorials i have ever seen it just works, renders fast and simple, i think when settings up softwares with presets like vmpp they didnt give rendertimes or complexity much thought, i have ended up tweaking yesterday some files from someone who used it too much and i must say, one metal shader was there rendering for god knows how long with a stuck bucket, i deleted the whole thing, simple material with fresnel did the same thing
Metals are all about what they are reflecting. If you have nothing interesting behind your camera to reflect, you will see nothing interesting in them.
Your wall tiles look like they are a matte material. That will also reduce the secondary reflections.
