I have an extremely simple scene - when rendered locally the teapot reflects in a certain location on a glass object, but when rendered with the rendernodes only, the teapot appears shifted to one side on the glass object. This is a huge problem because the buckets don’t match up when using DBR and the locally-rendered image should be the correct one, I would guess?
Same versions of max, vray 3.10.03 etc. on all machines. Also they are all Intel machines, i7s.
I can also confirm that the issue is not material-related. I created a fresh simple 100% reflective mirror and the teapot still shifts in the reflection on my render nodes, but stays in place on the localhost
I have realised that my two rendernodes are running windows 8.1 64-bit but my localhost is running windows 7 pro 64-bit. Could this make any difference? Again, same versions of max and vray across them all.
I’m going to completely uninstall vray from the two nodes and re-install fresh.
That was quick update, I just looked at images for your issue.
It might be due to different versions, did you get any warnings or errors when you installed 3.10.03 for the first time on the workstation?
You can send us the file for test in order to be sure that we don’t miss a bug here.
I’m not able to reproduce it here even if I use mixed versions of V-Ray.
However, I found that the issue is related to the glass Shell modifier. Here are the render results with and without modifiers:
For some reason the glass has been rendered without “Shell” on the main workstation.
It’s really weird. Something have fixed the issue, but unfortunately we have to find a way to replicate it again in order to troubleshoot further.
If you manage to find something or it happens again, please let us know.
I will keep an eye out for you. I think it’s going to be something regarding the shell mod, as you say, and how max behaves between restarts. Thanks for your help.
