I am looking at replacing our main server. We have a Synology NAS that is working well as a file server, but I am investigating something to act as a floating license server, backburner server etc.
Any reason to have a fully-blown Windows Server system, or should any old ‘stable’ PC running Windows 7 suffice?
If it’s just for licenses, then I’d say any old pc will do with Windows 7. No need to spend the extra cash on that. Rather take the cash that you would have used for Windows Server and instead get another render node
I have a problem with the “any old” part of that sentence. This is your floating license server, so if that machine goes down, production stops! Unless you are running redundant license servers. It doesn’t have to be a major powerhouse, but it DEFINITELY needs to be reliable and a long term solution.
But that’s just my two cents. I’ve had a license server fail and it really sucked! Took me almost two full working days to get all the licenses transferred to another machine to get the office back up and running.
We are about to migrate to a new tower-based server. In terms of the OS, any suggestions on this? We have had Windows SBS2003 for the last 7+ years. In all honesty, we use a fraction of the servers capabilities. We don’t even use it as a file server these days with dedicated NAS-based systems. It really sits there dishing out licenses for VRay, Itoosoft etc. That’s about it.
Should we be moving to Windows Server 2012 or something lighter/different but equally as stable?
If it’s just going to be a generic license server, you can just install windows 10 Professional and call it a day. Simple and easy to use and you can expand it to do other roles as needed.
Yes, I have Nuke, Autodesk Design Premium, VRay, Sapphire AE plug-ins, PDPlayer and a host of other licenses on my Win10 box. All working without issues.
If you wanted to, you could just use an older copy of Windows 7 Pro and just use that if you are too concerned about compatibility with older licensing software. (I did need to get different WIBU drivers for the VRay dongle, but that was pretty trivial)
It also allows for better communication between computers on your network…so computer name resolution works a LOT better. You can also setup startup scripts that run when a user logs into a computer and can prep various features.
Yes I understand all this. I use to be a system administrator and also an IT manager for about 60 users back in the day when NT4 was king. I never thought of deploying a domain in a small scenario like 10 or less. This thread however is making me rethink my IT strategy.
We are about 30ish people and we are not on a domain. I would prefer to be so it would be easier to manage the render farm and have a more centralized approach.
So am I right in thinking that you could set up a win7 VM on a capable NAS (QNAPTS453) then get it to run backburner manager, host the Vray dongle and the V-RAY license server. All this whilst acting as your file server?
Only asking as my current win7pro file/license server/dongle host, is an old quad-core Opteron(280) with a High-point RAID (10). BUT this can’t be upgraded to Win10. Old Opterons are missing an instruction set or something not supported.
This is a solid machine (supermicro) but is probably starting to show it’s age and I’m looking at alternatives.
I’m guessing it’d also be possible to keep the win7 server and the nodes/workstations as win10, is that likely to cause any problems on win10?
