Setting up custom assets
Hi! I am stuck and can’t find how to continue to create a custom asset. Attaching a snip of what I see. Working in Revit 2022, as you can see the “NEXT” button is greyed out.
click on the folder icon to select a folder where you want the asset projects to be saved
Thanks! So obvious.
I did not realize the folder was an actual button that lets you set the path.
Totally understand. You’re probably the 10th person I’ve spoken to that didn’t realize this. I think the design could be improved to make it more clear.
