Hi, everyone, i need help
I’m having a problem with my image result from enscape. The shadow on the tree trunks look like it didn’t render perfectly. Anyone seems to know the problem?
Thanks a lot, cheers
YdW4zRB.html (21.4 KB)
h94cHTp.html (21.4 KB)
](Q1 hosted at ImgBB — ImgBB)
@endarasman , thanks a lot for the report - just to first off make sure, are you using our latest release? If not, please ensure that this is the case, and additionally update your graphics card drivers to the latest version if you did not already.
If that doesn’t do the trick, can you also decrease the Field of View in the Main tab of the Visual Settings and move back a little to get everything into the frame again? Does that help instead?
Thank you in advance!
