i am learning to use vray, but here it’s the problem since 3 month, i thought i had followed the manual, but pls tell me why could my result of rendering happen? how can i resolve it? thanks in advance
Re: shadow question
You’re using the original VfSU release, right? There’s a bug where the V-Ray sun is not synchronized with the SU sun. Go to the Enviroment section and click on the M for the GI, then in the window that appear, click the Update button.
Re: shadow question
Hi Guys,
What do you mean by synchronising both suns? I was under the impression you can either override the SU sun or? Use only the Vray sun? I am confused. If shadows in sketchup our active does this mean your using the SU sun instead?
Thankyou.
Re: shadow question
i thought i followed the manual, applied shadow of SU for the sun and the control of the time, then choose big M of sky parameter in environment…anything wrong with my setting or really it is a bug?
Re: shadow question
No it’s not a big deal!
you just need to srt of refresh the vray sun settings. i ‘refresh’ it by going to enviornment>GI>deafult button>and reaplly the deafult. That’s it
