Hi All
I need to animate a parachute being deployed from cargo dropped from a plane. Can I achieve this with simcloth or would you recommend something else?
Regards,
Morne (DVP3D)
Hi All
Regards,
Morne (DVP3D)
I think you may be able to do this with reactor. Cloth for the parachute…splines for the cables (not sure if id use the rope modifier) and a block at the bottom for the main mass. I think then you can add air resistance to the cloth…
Or just keyframe it…it depends how realistic you want it.
Hmm sounds good, but I don’t see the scene file attached you made for me ![]()
I’ll give it a shot and post results in image uploads…
Regards,
Morne
I ended up doing this with morph targets. Turned out great for my needs as it is only seen for short while and its motionblurred.
Nice one. Glad you got it sorted ![]()
