Sketchup - Luminous Intensity dialog box bug
Hi All,
Just having some issues in Sketchup with Enscape lights - the luminous intensity dialog box has an issue when you key-in a value and the slider doesn’t move, or it jumps to a random number :confused: . ie. changing from 2000cd to 200cd (dropping a zero). This issue appeared in the latest release of Enscape only. Sliding the slider is unreliable and I need to be able to reliably key-in for my lighting values. A fix in the new release would be great!
Thanks!
Similar has been mentioned with other sliders such as the ones in the material dialog, I assume it’ll be fixed in an upcoming update.
