Since I installed the phoenixFD nightly of 13-09-2015 on all my slaves I can’t get a license for rendering with vray on all my slaves. What should I do?
phoenix and vray use common licensing settings and i suppose the installation has changed them. vray has authorization tab, you can open it to see the settings and check what is wrong
Same happend here earlier. The solution was to start Phoenix license server, not Vray license server. After that, all machines found license properly.
Yep, I run the phoenix license server to handle both phoenix and vray ![]()
It did the trick! My settings were ok but I had to launch the phoenixfd license server (I first tried to register the service but that didn’t worked. I launched the app. windows then asked me to allow it in the firewall. That’s strange that the vray license server is not working anymore…
well we still run vray 2 so I assumed the phoenix license was newer or something.. don’t know why but it works ![]()
I have the latest vray.
