Hello-
Here is something that causes me problems, but I just usually deal with it. When I pick the edge of a poly, hold the ctrl down to drag a copy, the poly gets this smooth modifier or something applied to it. I deal with it by detaching the new polygones. Once I detach the smooth modifier seems to go away. It is almost like the automatic smooth modifier that is applied to a loft.
Any way around this?
Do you have an image to illustrate this? It sounds like a smoothing group issue.
Here is a 30 second screen grab
try working in editable poly. Haven’t seen this before.
use Edit Poly, edit mesh is the problem. Edit poly is way better to work with too.
Yep…that is just a smoothing group problem. If you are going to start modeling in that fashion. Follow these steps and all should be fine. I just tested inside of Max2011 with editable mesh/poly with the same results.
Create Rectangle
Convert to Editable Mesh/Poly (Doesn’t matter which, this works for both)
Go to Poly mode, select all Polys
Under the Surface Properties Rollout → Smoothing Group Subsection → Click the “Clear All” button
You can now edge extrude with no smoothing group problems.
