Solid viscosity
Hi even when viscosity animated to 1 all the liquids falls down at the end . Any way to have a solidify option like ice that way the liquid will stay around the sphere? Thanks
Hey,
I don’t think you need such option. Please first check:
- If you have viscosity enabled for the Particles and the Grid under the Output rollout.
- If you have Wetting with Sticky enabled under Dynamics.
- .. and if you have Wetting enabled on the sphere that you want the liquid to stick to.
Without Wetting and Sticky even the most viscous fluid will still slide from the surfaces of geometries.
Hope this helps, cheers!
Thanks This did help. I think it is still would be nice to solidify/freeze the mesh because even though liquid does not slide off anymore it is still changing the topology every frame and does not look like ice. Thank you
