I have such a problem
i am using the 7 version of the corona render
I used to easily adjust the crown volumetric material
now he works in a country …
who can write a small manual on his tuning?
because i’m confused … he doesn’t want to work like before
Hi Alekru, can you please clarify what’s different in Corona version 7 and volumetricmtl from your experience? If possible please share some screenshots of your issue.
Thanks!
yes
i will send screnshot
I figured out what the problem was
with a new installation, there was a standard fog distance
10 meters
it needs to be changed - by increasing it and then everything will work correctly
