[solved] Mov file for texture
I’m really sorry as I know this has been discussed multiple times, but for the life of me, I cannot find any previous discussion!
I have a *.mov file as a texture I would like animated. This is working fine on my main PC, but my new build (windows 10, Corona 5 RC2, max 2018) it isn’t working. From memory I had to install a plug-in or program or something, correct?
Thanks for the answer…
EDIT: I remembered! Install quicktime! Thanks anyway.
Just a hint - next time it would be great to list the differences between the PC where it is working and the one where it is not. :wink:
I hope all is fine now!
Thanks.
Yes, good point. However, I knew it wasn’t the ‘fault’ of a PC, per se, but rather that I had not done/installed something on the newer one which I knew I had already done/installed on the older PC.
