[SOLVED] Sun not visible in view port/interactive suddenly?
I don’t know why, but my sun assembly head will not show up in my view port nor is is visible when in interactive.
Normally I use a daylight system with sun set to Corona and skylight to none. I adjust it manually to line up with the sun in the HDRI I use while in interactive, but all of a sudden it won’t show up. The compass is visible and I can select the sun, but I can’t see it, therefore I can’t align it to the HDRI sun. Did the last hotfix do something, or am I missing something simple here?
Thanks peeps.
EDIT
Tried another file and it worked there, then re-opened and remade the sun. Seems re-opening the file worked. Very weird
