some interior
Very nice renders and congratulations that you have solved the noise issue though the render time is high :slight_smile:
Well I say this because I get strange results even if I ignore render times.Although I increased material subdivisions and BF subdivisions locally I cant get rid of the noise without increasing DMC sampler max value and when I do this, my image goes darker and even kills reflections somehow.
In your renders, I think IM+LC version render is nice too and acceptable because it is inexpensive in terms of time and I see that Your IM+LC and BF+LC solutions look pretty much the same in terms of the overall brightness of the image unlike mine.
I wonder what causes my scene to get darker with BF.
I tried many different settings and testing many different thresholds and max rates.
I think we got a winner:
only 4 cores :
IM 30 minutes
Render: 3h 30 min
The only settings I changes was noise from 0.005 to 0.01 as Brett adviced, and all glossy mas subdivs to 128.
So on 8 cores it would be 1.5h I don’ I don;t see any quality difference. And don’t tell me it can be even faster :slight_smile:
The other good thing I noticed when using IMLC is much , much less memory consumption - 50%
With BFLC it was disaster !
Nearly 1/10 the original time is a very nice difference! Image still looks great to me.
/b
Phenomenal optimisation work there. If I were picky, I would perhaps single out the jaggies in the high-contrast areas (white pot against parquet f.e.).
This is probably due to your DMC sampler using the rather low noise threshold. Do you get massively higher render times if you untick that box and set the DMC colour threshold at 0.005?
hmm I will have to try it with color thresh unticked
You could probably fix that by clamping to a high value too - one high enough so you’ve got range, but just enough to sort the aa.
We mostly just use those bits as a cue where to add a glow…
Lovely images & great to see you got the the render time down.
Hi Lukx congratulations for the images and for the cutting times u got. I’d like to know more about the vraylights subds u used in the last settings u shown and about the curtains if u disabled from GI (uncheking visible to GI) or something about their shadows. Thanks in advance
The images look good and clean but I think there is still a lot of optimisation that could be done.
It would be a fun challenge if you want to send me the scene?
Yeah I suppose it would be a good way to find the way to treat as well the GI noise or shadows noise in shorter times without loose quality.
If Lukx would agree would be nice.
Jacksc02 in the meantime could u tell what settings or value u would improve? I’m interested in testing. Thanks in advance.Seems Lukx is no more interested to test, no reply from him :frowning:
