Recent project I did for a client…
Really nice renders !
the only thing catching my eyes is the space betwenn the cabinets in the kitchen.
the higher ones seem a bit too low.
Everything else looks pretty good.
Maybe a little dof would be good as well.
Yeah I might do dof shots just for myself, because client want everything crisp ![]()
And space between cabinets seems low because I need to use wide angle and vertical straighten perspective so it squashed a bit whole thing (look at coffee machine how squashed it is. Again what can you do when client demands wide angle with straight vertical lines ![]()
Very nice. I see you solved the noise problem!
you nailed it! spot-on ![]()
Holy shit. You need to start using a different method.
Nice renders though!
I’ve tried IMLC but the kithcen image, light got to travel deep and I was getting splotches whatever I tried…
have you played with SolidRocks?
images are quality, but I agree render times are a bit off. I’d go either one way or the other: very high dmc sampler settings, or high local sampling where needed.
where is the light coming from, hdr, vray lights, vray sky..?
You can get spotches with that, but it’s never impossible to fix. Do you still have that version of the scene and the settings?
Yes solid doesn’t help
I will try to render some sample
vraydome with HDRI map
Awesome renders man. /b
Very nice renders. Nice and bright and clean..nice one!
wow! nice renders.. i think rendering time is very high may b because of the rendering method you have used .. your curtains, carpet etc came out really good. I think for such clearity in the image( curtain, carpet etc), we need very high settings. in such situation i generally render image in two parts, one with very high setings & i render only those specific regions in VFB by using mouse track which need in high settings & rest of the image with normal settings & thn i club both in photoshop, in this way i save lot of time which vray take to render even less details area with high settings..
OK I’ve rendered kitchen with IMLC settings as follows:
This time I was rendering only on one (Q6600) and LC took 9 minutes IM took 1hour and image render 6hours. So let’s say 7 in total on 4 cores so on 8 it would be 3.5 hour !
So it’s almost 3 times better and I think quality is similar. But is it possible to crank the times even more without sacrificing quality ? ![]()
IMLC version (3.5H):
BFLC version (9H):
Those both look pretty good really. I wonder if you can raise your noise threshold now that you are using IM instead of BF? If you can get up to more like .008 - .01 it would probably shave off a bit of time. I recall (I think from a Chris Nichols video, but I could be wrong about that) that it’s a pretty linear increase in render time as that number goes down.
OKi doki, I will run a test but I guess I will have to raise glossy mats subdivs ?
