The top part of the lamp can’t be seen in the mirror refection
i have Rtx 3070 and I have activated all option for Rtx but no luck!
hey @huss191998 did you also set your Rendering Quality to the highest value in the Visual Settings?
Are you using the latest Enscape release, too? You can download it here, if not: https://enscape3d.com/download/
We’ve made great improvements with reflections in the latest releases. Still, with intricate, small or complex detail, there’s still a chance not everything will show up in a reflection.
@Kaj_Burival_1 I was using 3.5.2 during this project and upgraded to 3.5.4 to see if there’s any change but the problem still persist while using 3.5.4
@huss191998 in that case it’s likely considered too small for the algorithm responsible for the reflection.
So how to fix it? Should I tell the client the render Engine I use behaves weirdly these days ![]()
Hello, I have also had similar problems with reflections and translucent elements.
I use the latest version and ultra quality.
When I am close to the glass, all the elements and reflections are usually there, but once I move away, elements begin to disappear, such as the door in the reflection of the floor and this also usually happens with reflections in the glass itself.
